- 2,070
- 84
- Jan 6, 2003
Iowa City,
Iowa
You should really take a moment to consider your goals for this project. If you just want your car to be a little bit faster, then you're going about things the wrong way. A couple points to consider...
Either way you go - boosting a 2GNT, or opting for a factory turbocharged DSM - you NEED to know how to work on your own car. $7000 is going to vanish fast if you have to pay others to do the work for you. And then what do you do when you scatter the engine later this summer?
- You want to do as much of the work as you can for yourself. This is not just a bolt-on and forget it situation. Things WILL break and you will quickly eat up your budget if you have to pay others to do the work for you.
- If you just want to make your 2GNT quicker, you don't need to rebuild. You need to learn how to perform both compression and leakdown tests and share the results with us so that we might offer our insight as to the health of your engine. If it's healthy, there's no reason why you couldn't install the HRC kit for $3000 and run around town on 7psi all day long. Your car will be NOTICEABLY faster and just as reliable as before. Plus, installing the kit yourself will provide you with the experience and skills vital to keeping the car alive. After you've had some seat time at 7psi, you can evaluate whether you would like to put more money into a FWD platform or move on to another project.
- You can discount and ignore the opinion of anyone who would suggest installing a 4G63 into your 2GNT.
- You can also pretty much discount anyone who suggests you contact Shep for your 2GNT transmission. If he offers anything for the NV-T350, it's going to be extremely custom and there's really no need. Bill Hahn ran high-10s all day long on a stock trans with only a Quaiffe LSD and axles. 2GNTs may have weak pistons and rods, but our transmission trumps the DSM trannies. (I know. I have both.)
- Finally, if you want the fastest car for the least amount of money, you're working with the wrong car. A factory turbocharged, AWD model is going to provide you with the most bang for your buck. FWD to FWD, it's cheaper to make a turbo car faster, but you're still stuck with some peg-legged FWD-no-traction-having-BS at the end of the day. Nothing compares to AWD.
, you got that right
I used to use Haynes manuals as bathroom readers.
