Help Alternator relocation help
Critic4Du3ce
138
20
Apr 7, 2010
Ny, New Jersey
Ok I've been reading and still can't find a solid answer.. I have a 2g with a 2g swap. I've deleted power steering and so far I'm stuck on what's next. I have a Fluidamper crank pulley, Saturn alternator 91-97 SC/SL Series with SE Voltage Regulator And jay racing alt relocate kit. Which belts am I supposed to use? 1 on crank to alt and 1 from crank to waterpump? Big pulley or small pulley on waterpump? I want to ask about wiring BUT that's another issue
Wiring is straight forward, just extend wires and match colors. Run alternator on factory ac rib, run water pump on outside rib. Either leave small pulley there as a spacer, or make a spacer so the pullies still line up. Bow u wont have any way to adjust tension, so i grabbed a belt that had to be walked on in order to have enough tension and i have no slippage. I dont recall the length, i can get that info for you tomorrow when i go to shop.
Ok cool thanks a lot.
