HELP: 90 Rear caliper to line fitting
XLR8
250
20
Jul 7, 2003
Kingston, New Hampshire
I am trying to finish up putting my new winter beater together and I am having issues with the rear calipers.
They are the 90 style caliper that uses the fitting pictured below to attach the line to the caliper. Because the mounting hole faces straight out and not angled like other 1g calipers there is no way to use anything else. I tried using a regular flexible line but it still hits the inside of the wheel. I tried using a 2g front line but the banjo bolt is a different style.
I already called JNZ and they were able to dig this part up in caps but it no longer exists. For anyone who has had this issue before, what did you do? Does anyone have any of these fittings attached to some old junk calipers?
Any help would be great.
Here's a pic of the hose. I'll send the others to your Email.
Just realized mine are different after I posted the pic?? these came of my 90 and yours looks very different.....edit from after posting picture...
Mine are definitely different. Here is a pic of the caliper.
I guess the search continues, still trying to avoid buying new calipers for $90 a pop.
Thanks
