HELP! 2gnt engine harness
98420a
60
Feb 18, 2012
mentone, Indiana
I was in the middle of relocating my ecu inside while doing a wire tuck. my problem is that i lost track of the wires after some of my tags fell off. :banghead: SO my first question is, does anyone have a complete engine harness diagram showing wire colors? Also what is the difference between a 95-96 and a 97-99 harness. are they swappable?
Not sure Why you would relocate your ecu in the first place but do a Google search on the wire diagram. You will find it Pretty easy. I'm on my phone or I would post a link. You have to ground a lot of your wires so don't forget those or your car won't even turn over let alone fire up.
I think your hosed.. Sorry man. the ECU pin out may not help because there are several wires that have the same color.. Im not sure if those harnesses are swappable, but there should be 44 wires going to the sensors ( im in the middle of doing mine). I think there's a total of 80 wires, since im auto. GL.. sux bro.
well i figured it out. All the wires are differently marked. I just had to look realy close. And i was relocating it inside the cab so i had room to start fabbing up some of my turbo kit im putting together. The ecu was in the way of how i wanted to route it. But thanks for the link to the diagram, it helped.
