TimIacobucci
- 82
- 5
- Jun 21, 2009
Orlando,
Florida
I was installing my new ss exhaust studs today as I was replacing the exhaust gaskets which had many horrible leaks. It was all going very well and I got them all in without a hitch. Didn't over tighten at all, just barely snug in the head. I am very wary of tiny aluminum threads.
So I put the manifold back on and half tighten a nut on the left and right to hold it on. I did the left first, like I said only halfway, then I started to tighten the right a bit more and I felt a weird pop. I look back over at my first nut and the stud has pulled out of the head.
I pulled the manifold back off to find an old helicoil wrapped around my new ss stud with a nice pile of aluminum caked in it's threads.
I also managed to mangle my new exhaust gasket trying to wiggle the manifold off with the gasket stapled to it like that.
Here is the offending helicoil and the nice new hole in my head.
So far all I have come up with for a repair is this.
++ BIG-SERT Oversized thread repair kits ++ thread repair kits for oversized holes, previously repaired threads oversized holes
Not cheap or readily available. Does anyone have experience using these timesert thread repairs or have any other suggestions I might be able to try out here?
Also with the gasket tweaked and seperating like that I assume I should get a new gasket right? Or will it smush back together when clamped down and torqued?
The tubular manifold I have has a beefy 1/2" flange and will put a nice clamp load across the gasket. I couldn't figure why the hell some of the manifold nuts where on there so loose allowing it to leak like it did. Well now I know, shitty helicoil repairs in the head!
