2G Headlight Wiring question
wickedz
736
5
Dec 12, 2009
Madison, Wisconsin
Ok guys Im installing my body kit tomorrow. My car is a 95, so I went ahead and picked up a set of black housing 97-99 headlamps. I believe they are halo whatever bs, but no bulbs. The wires have been cut from the head lamps themselfs. I wanted to wire in my harness from my 95 lights and use the 95 OEM bulbs, can I do that? Im not looking to hook up halo right now
I havent seen a set of halos that utilize the OEM bulbs. So I'm going to say no they wont work. But you can use the wires from the 95 headlights.
most likely the bulbs used in those projectors are going to be H3/H7
Start by figuring out which bulbs it requires and then find a harness that fits it.
same ends as the oem bulbs for my oem harness?
oh i didnt see all your reply widow thanks for your help man.
