headlight fuse pulling .54amps draw?!?! parasitic draw [SATURN Alternator]
ApexVIII
812
5
Jan 12, 2008
Modesto, California
ok sooo,
i am getting .50amps draw, i think i should be at like .005amps or something which is causing my battery to go dead really fast.
i pulled all the fuses in the car and nothing changed. i pulled the radio/ room lamp on the under hood and it dropped to 0.43
then I pulled the 60amp fuse under the hood for the Fuse (+B) Fusible
and it dropped to .43 again
so then i pulled both the radio and the Fuse(+B) and it stayed at 0.43
then i pulled the 40amp from the under hood headlights and it dropped to .08 then i pulled the radio one again and it dropped to .01
so it seems like the head lights at causing the draw, i do have HID's, i unpluged them from the balasts and it did not change the draw at all. it stayed at .50amps
any deas?
EDIT: i would like to note that this is with the headligths TURNED OFF!
i am using a multi meter, and it it with the neg terminal off and the neg. Multimeter wire going to the terminal and the positive wire going to the neg batterycable
Disconnect the balast power supply and see what you get.
LOL i thought that i did, but then i realized that what i did was disconnect the ballast from the wires that go to the HID bulb.... at least i think i will double check this again later tonight when i get home.
does any one have a wiring diagram that i can look and see exactly what all goes threw the head light fuse? is high beams, headlights maybe foglights??(i dont have any)
Ok. I am an electronic technician. A 500 mA drain is a little high but not unusual. Most ecm/ecu's draw that much. A fully charged car battery should be able to supply that for months before becoming fully discharged. So you have some other problem you have not mentioned. Would "abnormal/premature battery discharge" describe it? Is your battery in nominal condition? Is your battery charging properly?. Is your alternator output
13.6V @ 60A load? Please describe your actual problem. Test and verify each component
in the charging system.
i am running a Saturn 95amp alternator, i get mid to high 13v driving
if i turn my headlights on and the fan for the AC or heater on high i can dip down to low 12's at idle but driving i am maybe low 13;s with both of those on.
i thoguth 50 to 25mili amps is normal anything above that was to much? im saying i am at .50amps so half an amp
how are you measuring it, and where?
i should note that this is with the headlights OFF, nothing is reciving power to it, just what normally draws current when the car is off,
that is the problem because the headlights should not draw any where near this ammount of amperage when they are not turned on.
Not true with car off! The ECU and radio memories together draw less than 50mA max.
You don't have the interior lights on due to the door open? Aftermarket alarm? Try pulling the headlight and taillight relays to see draw effect.
i do have an aftermarket alarm,
when i ran the test no doors were open and no lights were on, i opend the door just the check and the number jumped LOL
do you know what all runs threw the headlights fuse?
umm have not heard of it LOL, so probably not
wanna share what it is? LOL
SoundDomain: "Big 3" Upgrade Thread, With Pictures
That should fill in the blanks for everyone. While you have a separate issue, I recommend this to everyone. It sure don't hurt and the results are well documented and this is not limited to just the audio enthusiasts.
Hope you solve you drain problems though!
The 40A "headlamp" fuse powers the alt, headlight relay, and taillight relay. The headlight relay then powers the headlights themselves, fog lights, hi beam indicator, stock theft alarm. Try disconnecting your aftermarket alarm to see drain effect.
did not even think about that LOL i will try that right now!! thanks!!
ok, this is is not
Alarm,
Gauge cluster (LED's)
HID's
Headlights
update
well its the saturn alternator, i pull the plug and it drops from .54 to .08
the alternator should ne draw any amp,s being that it is a saturn alternator correct? so it only has the 2 wires i think its the Field and another one
There's a weird parasitic draw issue with Saturn alternators if they are not wired up correctly. I'm pretty sure my friend found the cure for it over on the Link forums...I see that you have Link, so you might try searching over there. Or PM JackM here (owner of JacksTransmissions) and see if he'll tell you himself, or give you the thread over on the Link forums.
ahh ok sweet i will pm him now!
