Parasitic draw 20A MFI fuse
Gerg
124
4
Dec 19, 2012
Cheyenne, Wyoming
My Battery dies Almost instantly When I Hook It Up In My Car. I Did A Parasitic Draw Test And When I Unplugged The 20A Fuse On The Positive Battery Cable It Went Away. How Do I Go About Fining The Short Or Draw Through This Fuse? Sorry About The Caps My Phone Isnt Cooperating WithThe Forum.
Thanks Bud. Glad I Have An Extra Harness I Can See Where The Wire Runs to Inside The Car, Sorry About all The Capitals.
So Ive taken all the tape and loom from the harness going from the positive battery post all the way to the mpi relay under the radio. I'm not seeing any evidence that the wire is corroded or spliced anywhere between the fuse and the relay. The plug on the relay looks fine and the wire isn't too brittle or cracked anywhere. I'm at a loss for what to do. I might just solder the best connectors out of the two harnesses to the harness that isn't in the car, and then switch the two out.
I had the same problem which is now completely fixed...
First get a multimeter and measure exactly how many amps worth of draw is being pulled from the car...
Then start unplugging, removing fuses til you find the circuit....to narrow down the possibilities that is...
My draw was due to the previous owner installing a jumper cable between pin 5 & pin 10 of the mpi relay thus keeping the mpi relay and ecu always powered up when car is off.... (Ecu went to Thomas Dorris who told me a circuit was fried and wouldn't power up on its own.... Thus the jumper...)
I removed the jumper had the ecu overhauled all is well...
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
