Head to Block Newbie Question
XiKeiyaZI
6,994
88
Dec 28, 2008
Goldsboro, North Carolina
I'm at work, so i don't have a whole lot of time to search.
Will a 1G 6bolt Turbo HEAD bolt directly onto a 2G 7bolt block? No fabbing?
If so, what all has to be done?
Thanks.
it's still a 4g63 engine the only difference in the 6bolt to 7 bolt is the crank/ bolts on the flywheel so yes a 2g head will bolt right on a 1g block
Vice Versa man. >__>
6bolt turbo head on 7bolt Turbo Block.
Yes it will bolt up fine. The 1g head has 12mm head bolt holes and the 2g head has 11mm holes. The head is positioned to the block with locating dowel pins which are the same for 1g and 2g heads. But the intake ports are different. So, if you use the 1g head get a 1g intake manifold to go with it. I hope this helps.
Awesome! ;D So I just have to use 11MM bolts?
This helps tons. I have a spare 1g intake manifold. ;P
;O!!! Awesome!!
I may have to do this with my NT head. I have a small tic...
Great advise. ;P
