2G Head removal help
screwlegg
5+ Year Contributor
34
Jan 27, 2018
Sebring, Florida
So this is my first time working with engine components, I just have a few questions and if someone can point me in the right direction for a step by step guide or something of the sorts.
First off is everything pretty much bolt off or is their some stuff that's more into it then that.
Second where do I even start or does it even matter just exhaust/intake/fuel/belt & ect
Third is what would I need when replacing the head just a gasket set or would their be other stuff I need to buy
Drain engine oil antifreeze remove turbo intake manifold thromostat housing from head remove timing belt then pull the head off at TDC
http://www.vfaq.com/index-main.html
Save this web page its very useful!!! :hellyeah::hellyeah::hellyeah:
Just went through the vfaq page but didn't see anything about removing the head I found a couple of thread but they help but not as much as I need help with I guess LOL. I might try the service manual way
Buy a factory service manual for an eagle talon. They should be on eBay for $20 or less and they are worth their weight in gold.
Again the most complicated process you will have to perform on any vehicle; is setting the tension to the factory tensioner arm and pulley
So follow the guidelines to change the timing belt
After removing the timing belt un bolt the turbo from the exhaust manifold.
Unbolt the intercooler pipe from the throttle body, remove tb, remove the vacuum hoses. Disconnect the injectors, coil, ac compressor plug, and move that harness over to the battery area (battery should be removed already)
After you remove the wiring and all vacuum hoses there are 2 bolts under the intake manifold holding it to a bracket which bolts to the block. You will need to get under the car to in bolt these.
Un bolt the thermostat housing from the head, it's 3 bolts to the head
You can remove the head with the intake and exhaust manifold still connected, the cam and cam gears still intalled
Remove the valve cover, remove the 8 head bolts
Wiggle it front to back when you try to lift it.
Oh the vaq wasnt for steps to remove the head it a good tips and tricks to read for all DSMs and the Haynes repair book is good for it too for step by step. It didn' let me down
