Head Noise at higher RPM
They are all version two save for a single one which is version 3.
Ok so is it possible for brand new 3g lifters to be bad? I just swapped out my lifters about 200 miles ago and while it is quiet at idle it has a horrible tick around 2500-3000k rpm sometimes so bad the knock sensor comes on?? How do I check to see if a lifter is good/bad? thanks in advance, and the lifters are TOPLINE?
Yes. Even brand new parts can fail. Look for a collapsed lifter.
Did you properly bleed them before installing?
