Head lights always on!?!?!?!
zaderian
Mar 20, 2008
Colorado springs, Colorado
My head lights wont shut off? it just started today and I'm not sure why? even when i turn the switch off, and i shut off the car they still stay on. I have to pull the main black fuse for them to shut off. Is there a bad relay or something? and where would it be?
Could be a bad relay or bad switch. The relay is under the hood in the fuse block to the left of the engine bay. find the headlight relay and switch it with a different relay for the AC compressor or something not important. If they still come on then you have a different problem. Possibly wiring or the headlight switch itself.
ok i tried switching the relays and nothing changed. :cry: however i noticed just now that one of the t-bolts from my inter cooler piping has penetrated the wiring harness, when i removed it that seemed to fix the problem LOL.
