head gasket or head, need help!
rs2nr
122
May 4, 2004
Stockton, California
o k guys recently alot os smoke has come out of the exhaust i mean a whole lot clouded up the whole block, so we checked and noticed that oil and the coolant wre mixing because it was foaming up white stuff in the coolant, so we fugured it was the head gasket anyways we took the head apart and the gasket seems fine, and we dumped the oil out and there is no water in the oil, so now I am stuck do you guys think it is a bad head or can it still be the head gasket, any info would be greatly appreciated thanks guys.
my headgasket did the same thing about a month ago. make sure to get the head checked to make sure its level. get them to check the block aswell, as it might need to be skimmed.
the gasket looked ok, but it was still leaking....then my turbo went. always fun
