Head gasket bore size on stock motor?
B-lackGSX99
112
Nov 9, 2006
Edmonton,
I've got a leaking / blown head gasket and am going to be replacing it with a new cosmetic head gasket from extreme psi along with a set of arp head studs. The only thing I don't get is what "bore size" I should order. My motor is all stock (aside from the HKS 272/272 cams, my profile is up to date), should I just order the 85.5mm?? 86mm?? 87mm?? I would just order a standard MLS head gasket from another site, but extreme psi does the arp head studs combo for a great price, so i'd like to just order them from the same site. I have searched quite a bit and have been unable to come up with explanations or answers. Should I just forget it and order a standard head gasket from another site, and then just get the head studs from extreme psi?? Greatly appreciate your help!
Will do, thanks guys. I'll just tell the shop to order the head gasket straight from the dealership, and I already have the arp head studs coming in the mail! Let's hope that my issue is indeed a blown head gasket! In case this is useful to anyone else, my symptoms are (in order):
1) Black exhaust / oil on front passenger side of motor.
2) Idle surge at idle (1000 - 1250 rpm jumps ever second)
3) Loss of oil.
4) White smoke coming out of tailpipe when stopped and at operating temperature.
5) Temp gauge maxes out. (only let this happen once, and temp becan decreasing after 5 minutes).
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
