Head Cleaning/Timing Belt/Reassembly
9!'clipseDOHC
Moderator
4,913
484
Aug 24, 2003
El Paso, Texas
I've been busy the past 2 days because I got my engine back from the shop. The block had been machined and built (Wiseco pistons, 6 bolt rods, BSEK) but the head hadn't been touched and still needed to be cleaned out before I could reassemble everything.
I removed the camshaft bearing caps, camshafts, rocker arms, and lifters. I used 2 cans of brake cleaner and cleaned out the entire head and all of the oil passages. I also cleaned all the carbon build up on and around the valves and the deck. I reassembled the "guts" and torqued everything down to specs.
Once the head was finished and both deck surfaces were cleaned, I installed the APR head studs, the OEM head gasket, and mounted the head on the block.
I set the timing with my Gates Racing timing belt and all new Mitsubishi timing components. Man it's a lot easier without the balance shafts!
Once the timing was set I reassembling the rest of the components. I've done everything I can do with the engine on the stand. All that is left is to install the Fidanza flywheel, ACT clutch, and transmission and drop it in my empty engine bay.
One little thing I'm excited about is where I mounted my fuel injector resistor pack. I mounted the it on the intake manifold support bracket. I'm trying to keep the engine bay clutter down by minimizing the amount of stuff off the firewall. This should help. :thumb:
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
