head bolt torque
90 Talon AWD
148
Aug 27, 2008
jonesville, North Carolina
i have a 1990 eagle talon tsi what is the head bolt torque? Chilton says 14.5 than 2 1/4 turns than autozone says 65-72 in three steps and says i have to get new head bolts and i dont know what is right. Thanks for the help.
Here are the correct methods for torquing down your head bolts after replacing a head gasket or doing any head work. Also note these procedures are for stock head studs.
Here is a typical #'d layout of the headgasket. It is always a good idea to tighten the bolts in order from 1-10 for each step
420a
1. Torque all center bolts to 25 ft-lbs, torque the 4 corner bolts to 25 ft-lbs
2. Torque all center bolts to 50 ft-lbs, torque the 4 corner bolts to 50 ft-lbs
3. Re-Torque all center bolts to 50 ft-lbs, re-torque the 4 corner bolts to 50 ft-lbs
4. Tighten all bolts in the sequence from #1-#10 an additional 1/4 turn.
4G63
1. Torque all bolt to 58 ft-lbs in order
2. Loosen all bolts completely to 0 ft-lbs
3. Torque all bolts to 15 ft-lbs in order
4. Tighten all bolt 1/4 turn in order
5. Tighten all bolts an additional 1/4 turn in order.
ARP Head Studs
1. Tighten all bolts to 40 ft-lbs
2. Tighten in steps of 10 ft-lbs increments until the specified torque that you are looking for is reached. This can vary with the amount of boost you plan on running.
GOOD LUCK
ok Thanks man that is what i was looking for. Thanks
Also, i thought the head gasket was just good for one torque.
