Having problem mating 3" downpipe to stock Turbo....
Street Lethal
Nov 13, 2005
Old Bridge "Raceway Park", New Jersey
We just recently purchased Pacesetter's ceramic coated header, and downpipe.... but kept the stock turbo in tact (95-GSX). Now, we're obviously upgrading to a bigger Turbo in the future, but for now, we're stuck running with the stocker.
The car now has a full three inch exhaust, and everything went on rather smoothly....except where the downpipe meets the stock turbo. We were able to mount it, but securing it with 1/4 inch nuts is impossible. The welds on the downpipe are in the way of making it seat properly. I was going to file the welds down on each side of the flange to "make" the nuts seat, but am having second thoughts.
I'm not sure what you call that part of the Turbo (where the O2 sensor is located), but is there an aftermaket piece that would adapt to the larger downpipe.... or do we simply need a bigger Turbo "now". Should I just grind down the welds on the downpipe's flange (not all the way around, just where the nuts fasten down), or should I discard this concept.
If a new turbo is needed, any suggestions?
We'd really like to run the stock Turbo, at least until spring... so can anyone give some good advice?
Thanks,
SL
Hi. I think you idea of grinding or filing the welds down is a good idea but be careful. Also, it would be a good idea to get some high temp paint once you file your welds down to prevent rusting. Changing you O2 housing (thats what its called) or turbo wont fix the problem your having. Have fun :thumb:
Good tip, thanks. Yeah, we pulled the down-pipe off and filed down the welds just enough for the nut to seat properly. But before we bolted it down, we gave it a shot of some high-temp paint... then applied some more, after it was bolted down.
So far, so good. :D
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $230 + shipping and paypal fees* these are out of 2GB so you get a...
  • For sale 2g 2G GSX/GST Front Knuckle Set
    2G GSX/GST Front Knuckle Set $150 + shipping and paypal fees* on the L side Knuckle the little...
  • Wanted Looking for an Evo 3 16g
    Anybody selling one let me know. Tried ebay and its all knock offs
    • heresjimmy42
  • For sale 1g 1990 STM shifter base bushings
    1G 1990 STM shifter base bushings.
    • drich970
  • For sale 1g 1G Radium fuel rail
    1G Radium fuel rail with built in FPR -8an feed and return
    • drich970
