having a rear drive shaft prob
DoggTalon
69
Jun 13, 2012
Mankato, Minnesota
where the rear transfer case and where the shaft goes on it rattles when you are driving or when you rev it up... it looks like the shaft should be moved up inch or 2 case were the shaft and the transfer case you can see like a little gap in there... i would like to know what i should do and what i should look for
does anyone have any ideas please help
From your explanation it is hard to understand exactly what is going on. You say that the drive shaft vibrates when you rev the car. Is this when sitting still? IF so that doesn't make any sense at all because the shaft is totally disengaged from the engine. If it is when driving down the road that makes more sense.
would it help you a little more if i took a pic of it and put it on here if i can
it does it when im driving to
Can you have a native English speaker post for you? For all I know, what you call "the rear transfer case" the rest of us call the rear differential.
There's quite a bit on shimming the rear diff, if you look around. I don't know enough to help, other than provide those search terms.
