420A Hatch wiring
Cfrakes
63
Jun 6, 2021
Idaho
Does someone have a wiring diagram of the hatch. I took it off and I didn't realize the passenger side had a single grey wire running through to the body and it broke and I was curious what that grey wire runs
I believe you are talking about the hatch glass antenna wire. It is thicker than normal and shielded. On its own it is awful and will just give you static, so if you are using digital streaming or still have the antenna on the rear body panel you will not need it.
