Has anyone used Supertech Valve Guides before?
Robertm1212GST
146
Feb 24, 2008
Spartanburg, South Carolina
Building my head and all I need to pick up is valve guides. I was looking into the Supertech Guides and was wanting some input on them good or bad. Here is everything that i have for the head build
BC 280 cams
BC Springs and Retainers
Engnbldr 1mm S.S. intake/exhaust valves
3g lifters
Any help would be great thanks guys!
Quite a few people run them and even more companies use that as the defacto valve guide in their cylinder head builds.
The over sized guides are used when the guide bores get wallowed or gaulled. if the stock guides knock in properly and have the proper press fit, you will not need them. bad thing is you will not know which guides you need till the old ones are knocked out.
Also remember the seats will have to be cut so the seat will be index to the center line of the guide.
Here is a link to a post I did for changing the Valve guides.
http://www.dsmtuners.com/forums/newbie-forum/341218-how-change-valve-guides-4g63t-head.html
Why not use the Engnbldr guides? I have them with his valves and have no complaints, my machinist said they were every bit as good as Supertechs.
they are, and probly made at the same factory too,
I have lots of engnbldr parts over the years with out issues, same with engine tech parts
