Has anyone repaired a stuck pushbutton on the dash?
1990TSIAWDTALON
Moderator
13,231
11,231
Nov 14, 2013
Independence, Kansas
Well I'm workinv on the inside today and my fog light push button is stuck in the on position. Not a bad thing but I would sure like to be able to turn them off if I was just parked. Any help is appreciated. I can't feel the spring load under the button. Thanks!
I wasnt suggesting that all i was saying is i may have one, if its broke its broke i cant see how it could be fixed i could be wrong whenever i have a bad switch i replace it, unless it can be fixed? all these years never fixed one, just got one that was working.
Well replace or repair either is ok with me. I've torn apart small switches before but it feels like the return spring may be broke. It won't pop back out. Thanks for the advice and if you do have a switch that would be real easy.
Thsnks. :)
Yes Fog Light switch. I am not going to let this bother me since it is in the on position but would be nice to have it work, because everything else does. Im kind of that way, like my stuff to function correctly. Thank you!
I have tried to pull it out, but maybe the previous owner glued the darn thing cause its not cooperating! I will check Vfaq's. Thank you.
Well much appreciation on the work it took to look for me. Do you know if they are available new or is a salvage yard switch now my option?
You'd be better off getting one used. JNZ Tuning lists them new for a smidgen over $50 and you'd probably want to contact them to make sure they can still get them. The OEM part number is MB522126. It's a bit pricey for a simple switch you can find in a junkyard for a few bucks.
Victor, this isn't the classifieds. If you have something the OP might be interested in, take it to PMs and offer it. There is no reason to clutter the thread.
That was way easier than I ever thought. Its fixed. Case closed. Thanks so much!
