Resolved Hard wiring MAFT underhood ?s
grdsm
51
Oct 12, 2007
GRAND RAPIDS, Michigan
I purchased a maft from a fellow tuners and it is missing the plug to the stock maf. I am going to hard wire it under the hood and i got all the wires were they need to go but The only question is do I run the pink wire from the maft to the red wire on the stock plug or do I run it to the green W/ red wire on the stock plug?
Also there are 7 wires on the stock plug and only 5 that need to be connected from the maft correct?
The white one from the maft goes to the cas.
Solution
As far is i can see in the dark...
Pink-red
Green-green with blue stripe
Brown-green with red stripe
Blue-green with yellow stripe
Black-green with black stripe
Pink-red
Solution
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
