Hard to shift gears..
Kiiii
37
Sep 9, 2009
OXNARD, California
so here's the deal
its hard for me to shift gears unless i pump the clutch pedal a few times
its easy to move the stick shift around when the engine is off though
i've noticed my slave cylinder has lost some of fluid, but i don't see any leaks on the ground
whats up here?
Have someone pump it while you check for leaks while the car is on. If none, bleed it out and refill it with brand new fluid.
I call it a TO bearing hanging up for why would motor operation have control over the clutch hydralic system?
I would also check tranny fluid (and only SP+4 goes into that Chrysler tranny) for it could be pig low, or needs to be changed out.
