javier347
- 92
- 0
- Oct 28, 2004
Valrico,
Florida
I am building a 2.0 7-Bolt, the block has been machined to .20 over.
I am running Carrillo rods with Wiseco HD pistons. I installed the crank a few weeks ago and i can rotate it by hand with no issue.
Today i installed the #1 piston but as i am rotating the crank and the piston is on the way up it gets a bit harder to turn. When ahead and installed the #2 piston and it got a bit harder to turn by hand. I can turn it with a ratchet with no issues but i am not sure if this is normal or if something went wrong with the build. I am with in clearance for piston / rods, any ideas if this is ok or if something is actually wrong?
Thank you.
Thank you.
