Hard Stutter Box Setup Question!
novatsi
May 17, 2003
Sup, just hooked hookup my Msd Stutterbox. Question is, when clutch is not pressed and I step on the gas, rpm stutters, but when I press the clutch in, it doesn't stutter, is this working properly. Its seems to me it should work the other way around? Shouldn't it be when clutch is pressed in, it'll stutter? I hooked it up to a 2 pole relay, 86-87 coil, and a normally open contact. Please let me know what you think, Thanks.
Yes, it should be the other way, unless you do all your racing with the clutch pushed in.
Hook it up to the normally closed contact.
Yes, thanks for the info. However, I already figured it out. You need a normally closed contact. Problem was, you would think that the coils weren't energized before pressing in the clutch. Wrong, the coils are energized which would cause a normally open to be closed. So, by hooking it up to a 2pole relay with a common with the option of a close and a open, just hook it up to the close. Cool, this works awsome.
