GSLENK
- 1,416
- 55
- May 25, 2011
DC,
Maryland
Car takes extra time to start while cranking. When the engine finally catches, it starts rough out low (like ~3-4-500 rpm) and quickly but roughly gets up to normal cold starting idle (around 1400, then down to 1200, then 1100 and eventually to the 900 rpm idle as it reaches operating temp.
It seems to get worse with the hot weather. It seems like the car is heat soaking after shutdown and causing something to happen. I drive calm for the last 5 minutes of my drives (no/minimal boost), and often idle my car for a few minutes (or a complete auto fan cycle, fan off, fan on, fan off, shutdown).
Ecmlink shows my temps maxing at 213 on hard driving/hot day, 200-206 normal hot daytime driving. 196-200 cool night. I dont think im over heating.
I am not running the oem fuel system at all (only the tank to filter, and afpr lines are oem)
I read about hot starts and the need for hot start enrichment, but this happens on a cold car, in the morning, after driving at night.
Im running one radiator fan until I find a good solution or fit the a/c fan properly.
This has been getting progressively worse with the hot summer temperatures.
Any idea whats going on? and a fix?
