handling
crz40
Dec 9, 2007
CA, Ohio
allright i got a 92 tsi awd talon and its got a handling problem....... it feels real real loose in the back end like it wants to drift and 70+ its real jerky with the handling like almost if i did turn to much to one way it would break loose and spin out, its really unstable at highspeeds 100+ in a straight line..... does anyone have any idea what it could be
Does it have any suspension work done to it already? Springs? Shocks? Sway bars?
Has it had an alignment lately?
Check your alignment. Play in the steering such as loose tie rod ends can cause that feeling.
A tell for play in the steering is behavior under breaking or cornering. If the play causes the toe-in to change to toe-out under breaking the car will tend to get squirrelly or feel like it's on ice.
Cut your losses before you build them up. Take the car to an alignment shop -not a chain like Good Year, but a local shop who's been around for a long time and has a good name in your town- and have them do an evaluation for you.
Just to throw this out there. My local sears does a free steering and front suspension evaluation....even though you said rear...you could check and see what they get for that too? LOL. But it might be worth looking into that. But I also agree with Defiant.
Agreed, but I would take it to a few places to get an average on what you are told. LOL
the suspension is stock, the steering wheel like pulls to left and to the right you can feel it when your hold on to the steering wheel
As stated before, I HIGHLY suggest taking it to a reputable alignment shop and have them give it a once-over. Even if you fix this 'first' issue there could be more that you don't feel/hear until its too late.
Having said all that, here is a quick list you can go through. (assuming your suspension is fairly stock)
1. Check tire pressure, condition and make sure they are all the same size and rotating in the correct direction.
2. Rock the wheels and make sure they are not loose on the hub.
3. While the wheels are in the air, grab the top and bottom of the tire and rock it. There should be no play in the wheel bearing.
4. Rock the wheel side to side and watch the lower ball joint up and down movement in the spindle. There should be none.
5. The lower control arm is affixed to the subframe via a long bolt and nut. Make sure they are there and tight.
6. Grab the tie rod end and make sure it does not move up or down in the spindle. It is okay if it pivots.
7. Make sure the strut is not bent and not leaking.
8. Make sure there are no cracks in the spring.
9. The upper strut mount should have very little movement...only the strut/spring should be moving.
10. Verify the steering rack is not loose on the subframe.
For the most part you can apply the same checks to the rear as well.
Whether you find something or not, take it to a shop for peace of mind if nothing else.
You can tell you rally ;)
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
