Halo Projection installation
TheDonDSMAk
45
Nov 1, 2011
Brooklyn, New York
Okay, so i got these halo projection head lights and i thought it would of been an easy task to install but im having a bit of trouble. I already took off the front bumper and disassembled the stock headlights. Now this is where i am stuck because of the wiring.
These 2 parts was attached...
But the Halo Projection has this...
So what do i have to do next??!
Pics don't show much. You should still have the plugs that connect to your wiring harness. Correct? If so;
The wires there are for the halo ring. You'll have to splice it into the wires that go to your corner markers.
I have a set of them. I spliced them in. I declared them weak sauce and unspliced. Them. Haven't attempted to resplice them back in again.
Those wires are for the halos only. You can either run the lights without them or do what i did and splice them into your bumper lights' wiring so they come on with them. I'm sure there are easier ways of doing it but whatever... it works.
