Halo headlights??
Sphinx
61
Apr 9, 2011
calgary, AB, Canada
hello, ive looked over the forums and have come to no avail. simple question, is there halo headlights made for the Talon model period?.. an earlier thred had revealed that there is a slight gap when installing the headlight on a talon, but i have done bumper work and headlight work on eclipse-talon before and i know that the talon headlight its self is around a 1/4" longer than the eclipse headlight and that the eclipse bumper is shaped differntly to compensate for the minor differance & vise versa..
ie: eclipse bumper on a talon will cover talon headlights & not fit correctly
ie2:eclipse headlights on talon will leave minor gap
further more & back to my origanal question, is my findings that aftermarket only made a "eclipse" halo headlight and not one specificly for a talon... or have i just simply been looking in the wrong places:confused:
From my understanding, all 2g talons use the same headlights as the 95-96 eclipses. As for halo headlights, I'm not sure if there's any made for 2ga eclipses. I know they make them for 2gb eclipses.
http://www.dsmtuners.com/forums/app...rior/395004-help-finding-halo-projectors.html
The search function proves useful if you actually try using it. Read the thread from the link I posted. Learn to use the search function and don't expect to have everything done for you.
i will have to dispute that comment .. seings how i personally had staited useing the "serch function" .. and even went as far as refering to other past threds... so as for having things done for me i disagree ... and an honest mistake on my behalf between 2Ga & 2Gb eclipse, also in refrance i had commented on knowing the size differance, wich is 2Gb comparison, although now through use of the forums i have aquired new knowlage of 2Ga DSM's ... however a rude mannor none the less a new tid-bit learnt for the day :thumb:
Ah, you are correct. Read your post, but didnt fully comprehend it. A mistake on my behalf. Sorry for the rude post, but it was early in the morning after being rudely awakened when I posted. Nonetheless, I found the correct thread you needed since you somehow missed it.
true, i may have also over reacted a tad, but i do appricate the help :D LOL and well i even ended up finding the headlight i was looking for ;) i appriciate the apology and well you deserve mine as well :p ... although i did try and keep it in the most "debate friendly" way could LOL hence trying to abide by the strict rules n such
you still drive an n/t :p
