GVR4 guys........ need some help identifying this wire!!!!
Morphius
DSM Wiseman
1,895
66
Jun 9, 2003
M-Town, Michigan
I did a 4G63T swap into my GGSX along with a complete GVR4 engine harness. There is a additional wire in the bundle that goes to the thermostat housing. Can you tell me what this is for???? Below is a pic.
It's not the A/C coolant temp switch, that here.....
its a ground or sum shit, i think it goes somewhere near or on the temp housing.
It's not for the coolant temp sending unit, that's here......
It's not for the ECM coolant temp sensor, that's here.....
And for referance, this is a T/E/L lower thermostat housing with a Galant upper neck. Not that it should make a load of difference, but the neck has one sensor, the lower has three. There are no other sensors to hook a wire to.
It's hard to explain so I took a picture. You can see my finger resting on the connector you're talking about in the pic. It attaches to a sensor on the backside of the thermostat housing, almost directly opposite of the connector that looks just like it.
Sweet. Thanks for the help!! Looks as though if I want to hook it up correctly, I should get a GVR4 lower thermostat housing.
BTW, are there service manuals for the GVR4 line like there is for T/E/L Dsms?? I need to get one.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
