GVR4 1st gear failure.
Are you or have you ever run a GVR$ 1st gear?
  • You I've run one; NO ISSUE'S
    Votes: 4 50.0%
  • FAILED - stock-300hp
    Votes: 1 12.5%
  • FAILED - 300-400HP
    Votes: 0 0.0%
  • FAILED - 400+
    Votes: 1 12.5%
  • WOULD RECOMEND
    Votes: 2 25.0%
  • WOULD NOT RECOMEND
    Votes: 3 37.5%
  • Total voters
    8
90gst_sean
566
10
Apr 9, 2006
Seattle, Washington
Are you or have you run a GVR4 1st gear?
Did it fail? If so, what do you think your hp level was?
Did it fail on the street or strip?
update: I can't seem to edit the typo's in the poll..?
If you are still running the gvr4 1st gear with out issue. What is you power level please?
I'm tempted to run one do to my relatively low hp levels; under 300. With that in mind, what do you guys think?
Are you running the GVR4 gear yourself?
The GVR4 gear is the actually weaker than the stock 1st gear.
The STRONGEST first gear available is the JDM 11% Taller Evo III 1st gear. It comes with the input shaft and is double syncro'd, and you can get it from TRE for around $300.
I do not recommend the GRV4 gear for high hp levels, and I know Jacks Transmission will install the gear if you wish, but I don't think they will warranty it if it fails due to it being weaker than stock.
No, I don't run one. I'm in the market for a tranny build and Jack offered to through a gvr4 in for free because he is waiting on a shipment of evo 1st gears to come in.
I don't run the track very often and my car is under 300hp. I'm just doing some research before I hold off for the evo gear I think.
Bwhahaha!
Get the EVO gear.....
That's funny because Jack has a warning right on his site about the GVR4 gear:
Jacks DSM, Eclipse, Talon, Laser Transmission service
  • For sale 1g 1G AWD Fuel Filler Neck
    1G AWD Fuel Filler Neck $75 + shipping & paypal fees* I would replace the rubber elbowYou...
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
