gt3582r set up
2gdanny
625
17
Mar 9, 2007
south river, New Jersey
hey guys so i have everything for my new set up i will give you guys a run down on what i have for the set up.
wiseco pistons
crower rods
gt3582r
dnp manifold
arp main +head studs
4 layer head gasket
walbro255
aeromotive fpr
fuel filter + braded lines and aem fuel rail
hks cam gears with power timing belt
dsmlink
afc neo
turbo timer
and all the other stuff
and not forgeting im getting the dogbox race trany with the spider gears
well my questions is as a right now with the 16g i was running with 2g maf and greddy 720cc injectors what injectors are ok for my set up (1000cc) and will i be over running my 2g maf?
showld i do a 3"gm maf and translater on my sbr fmic?
as a right now i have the sbr fmic with out the bt set up on it . can i just get the uper icp with the blow throw set up on it to fitt the sbr race front mount or just have soem one cut and weld my pipes for teh 3"gm.
i hope some one can help me out there becouse the car is going 2 dogbox in 2 weeks
1000's should be fine for race gas. I would deffinately get a gm maf to put on it. You can just cut part of your upper intercooler pipe off and weld beads on it to make it a blow through setup. That is what I did with my Buschur kit. Then you just buy reducer couplers to go from the maf to the intercooler pipe.
Why would you have an afc and Dsmlink?
yeah well the neo was a gift froma firend becosue i didnt have anything too tune befor i got the dsmlink and i just left it on the car.
well i did look at rcs 1000cc
and the 2g maf i didnt want to by anything or do anything befor i make sure and know for a fact i cant runn the 2g maf on the 35r with all the mods
and im planing on running pump gas you guys think its possibel?
maybe doing a meth injection down the road.:sneaky:
The injectors will be fine with pump also. I was saying if you use race gas over e-85 since quite a few people are using e-85 now. I am pretty sure you will over run the 2g maf with that turbo if you push it. With dsmlink though you can use the fake mas feature if you start to over run it and don't want a gm maf. Basically, buy some 1000cc injectors and start tuning. If you run into any problems post a log on Dsmlink forums. Myself and many other members on there are more than willing to help.
no ill rather do the rigth way i def dont want too run no getto stuff so if you where in my showes you would get the gm maf?
that will be good for my set up with the dsmlink and pump gas?
and sens i have a 2g with a 6 bolt do i get a 2g gm maf n translater or 1g gm maf n transleter?
and i want to thank you for your time and help.
I would get a gm maf but as I mentioned it is not needed. But it will be easier to tune. You would want to get the 2g maft since your maf wiring harness is a 2g harness. And then you can get a 3" gm maf.
I am glad to help out all I can.
thank you very muchme and my friends rented atco one more time we do it 3 times a year and on april first we got the track again and dog box is goign2 do all the motor work and tranny and they will give me a basic tunne and what ill do is just get the 1000cc injectors and at the track sens i can do as manny runs and pulls i want ill tunne is and see ### happens and ill post the logs after i get back from the track and im sure you guys can help me after.
and what do you mean by the fake mas thing?
i can find that on the dsmlink when i log.?
Go under ecu/logfile and click on airflow. Then near the right bottom corner there will be a box you can check that says fake maf next to it. The only reason to use that is if you over run whatever maf you are using. And then you will have to adjust the ve tables. Without using fake maf you don't have to touch the ve tables. That is why it is easier to use a gm maf when it comes to tuning it.
oh i think i have a clue off what it is well ill get the injectors and when i get the car back they said they will give it a basic tunne but ill just tunn it at the track and ill keep you/every one updated and thankx for your help
I am in NC temporarily. But I live in NY right outside of Syracuse. It seems like a good setup to me.
