Gt3582r Setup....Everything I Need?
j5819n
58
Sep 14, 2007
vancouver, Washington
So i was just wondering if this was everything i need or is i have stuff i don't need? i already have a tial 38mm and a 4" intake so i am really just asking about the lines and gaskets.
Punishment Racing T3/T4 Turbo Manifold: Mitsubishi Eclipse 90-99
Punishment Racing SS T3 O2 Housing: Mitsubishi Eclipse 90-99
Oil Feedline Kit w/ 15 Micron Filter (Head Location): Mitsubishi Eclipse 90-99 - Braided Steel Line (-4 AN)
- Earls 15 Micron Filter
- Turbo Fitting
- Aeroquip Fittings
- Crush Washer
Extreme PSI Stainless Steel 4 Bolt Exhaust Gasket: 2.50" ID
TiAL Wastegate Gasket : 38mm
Wastegate Gasket
Garrett/BEP/Turbonetics T3/T4 Turbo Oil Drain Gasket
OEM Oil Return Line Gasket : Mitsubishi Eclipse 90-99
Oil Return Line Kit (Stainless Steel Braided) : -10AN
T3 Turbo Stainless Steel Gasket
Mr. Gasket Copper Exhaust Manifold Gasket: Mitsubishi Eclipse 90-99
ARP 8740 Chrome Moly Turbo to Manifold Bolt Set: Mitsubishi Eclipse 90-99
2-Bolt High Temerpature Exhaust Gaskets
-1456 - 2.25" I.D.
Garrett GT3582R Turbocharger : 400-600 HP
GT3582R
HP Rating: 400-600
* Ball bearing turbocharger
* Oil & Water-cooled bearing system
* High Performanc...
Selected options:
Turbine Housing: T3, 4 Bolt 0.82 A/R (2.50" Discharge)
Compressor Housing: T04S (4.00" Inlet/2.50" Oulet)
Banjo Bolts w/ Water Lines
Comes with 4 crush washers, 2 Banjo Bolts, and 2 Steel Lines
Fits onto any PTE/Garrett water cooled turbo and T25/T28 Turbo.
should be assuming you have all the necessary supporting mods. If not, your grocery list is gonna be ALOT longer than that. Especially if you want 400-600 hp.
Fuel pump
pump rewire
FPR
bigger supply line
bigger injectors
internals
some type of datalogger
larger exhaust
intercooler
BOV
boost controller
Intake Mani
TB work
etc.
Its not journal bearing and i would suggest a restrictor...
yup i have been working on all the supporting mods the last two months so i am set in that department. and what is a restrictor? and the water lines from extremepsi will work right? thats really the only question i have i don't remember if thats what they looked like the last 35r we put in my friends car
-1456 - 2.25" I.D.
What are the 2.25" gaskets for...?
oh that was supposed to be a 2.5" gasket for the o2 housing to downpipe and yes my fuel system is set 1000cc injectors, walbro 255 and dsmlink, fuel pump rewire, and an aeromotive fpr
