Does this package include everything i need *waterpump*
Well if you are changing your waterpump you will have to take off the timing belt to get to it if i were you i would order the complete timing belt kit as well. No reason to dig in there and not change the timing belt while you are down there.
well yea, im doing that too ( or have my friend who is a mechanic do it )
but does that package include everything ?
With that kit, your gonna have to reuse the pulley and pulley bolts. Shouldn't be an issue unless your pulley is damaged. I would also order a complete Timing Belt and Balance Shaft belt replacement kit with a new hydro tensioner. It would also be a good time to order new hoses and a new thermostat with gasket if needed. Check on some sites like extemepsi or ebay for the TB kit mentioned earlier.
  • Wanted 6 bolt NT water pipe
    • chrisman287
