GSX wheels
Heliarc
Nov 24, 2003
Salina, Kansas
Will the 17" wheels off a stock 97'-99' eclipse GSX fit on a 99' GS-T? I'm pretty sure the bolt pattern is the same, but off-set or any other variables I am not aware of?
o0_pyro_0o said:
http://www.vfaq.com/mods/macross/offsetFAQ.html
http://www.vfaq.com/mods/macross/2Gfitment.html
Read up
The wheels should fit but you may need to go with a 235/45 tire instead of the stock 225/50
Why a 235/45? The stock tire size for a '99 2G GS-T is 205/55-16. The stock tire size for the '97-'99 GSX is 215/50-17. Using a tire calculator, you'll be going 1.4 mph faster than what your speedometer indicates.
Does anyone know if the speedometer of a GS-T and GSX are calibrated differently, or is the 1.4 mph difference considered negligible by Mitsu?
