gsx fuel cut
DSMbert
Dec 3, 2009
Wadena, Minnesota
Okay, so i got the gsx runing last knight and now when i get into higher rpms it cuts out. My buddy thinks its a water temp sensor because we tested them and the readings are low but i dont understand how that would cause the cut out. My guess is the MAF sensor. Does anyone have any ideas that can help?
If you upgrade list is correct, then I'll assume you have a boost controller and turned up the boost? Have all sensors plugged in correctly?
