Grounding out timing on 1g
Eagle_Summit
796
Feb 6, 2003
Williston, North Dakota
Okay, I need to check my timing but I do not know where to ground it. I checked vfaq and they have a picture, but you can't really tell where its at.
So any pics, or a good detail description.
Just like in the VFAQ picture (even thought it is hard to see), there is a large plug right behind the negitive terminal on the battery against the firewall (there are actually 2, 1 large for the timing and 1 small for the fuel pump). Locate this large plug, pull the cap off and you should only see 1 pin in the connector. Hope this helps.
DaveT
92GSX
