Ground Question
zwickyj
205
Dec 11, 2003
Oshkosh, Wisconsin
The door itself is this a place to ground, the metal under the interior door panel?
My shaved door handle solnoid, and instead of running a ground wire into the car I was hoping this would work. Also infact just from mounting the bracket to the door panel is that grounded or should I run a wire from the bracket to a spot on the door?
Either way will work. If the bracket is metal, and is mounted on the door with metal bolts, then you can run the ground wire to the metal bracket or to the door.
