Grinds in 1st and reverse
JBDdsmer610
508
8
Mar 4, 2006
easton, Pennsylvania
OK i will go to put it in 1st and it will grind sometimes the same thing with revers i have a stage 1 clutch in it i was wondering if i need the slave ext rod. And i just looked under my car today and i saw something dripping and i put my fingers in it it was like silver with matalics in it. its dripping right off x-case but i dont think its comming from x-case
common problem with 1g's. Not much you can do about it really, syncros are just goin bad in the transmission.
I put stiff bushings kits at the shifter and the transmission. I replaced the lube with BG Synchroshift and adjusted the cables. No more problems.
