1st and 2nd grinds
Eclipse 1998
240
33
Jul 21, 2010
Bloomington, Indiana
So long story short i replaced my clutch and resurfaced the flywheel and i went to start the car and it slips out of 1st and almost outta 2nd, and when i downshift only from 3rd to 2nd it grinds really bad, come to the conclusion i need a tras or a rebuild any suggestions before i drop some cash?
Put the car in neutral, don't press in the clutch.
Start with 5th gear, and try to push the stick into gear.
You should notice a slight rpm dip as the trans starts to go in to gear.
Proceed through out the gears 4-3-2-1 If you do not notice this dip in rpm as the trans starts to go in gear then your synchros are shot/going bad.
You made sure the clutch pedal was correctly adjusted, right?
I'm currently in your situation, except I need to pull mine back apart and check the clutch release fork and pivot ball. (Plus I bought a new flywheel, TOB, clutch release fork and pivot ball)
