spyderdrifter
- 5,430
- 862
- Jul 11, 2009
Somewhere in,
Colorado
I know some of you may tell me to search, but I've spent the last two nights not sleeping in order to get my engine put in and all hooked up, and I'm too tired to really care. I just need options. I finally got to start it about 30 min ago. It fired up after cycling the fuel, but it's having issues and doesn't want to stay running without the throttle being held. I've decided to try the emissions delete again, and this is my first thought for why it's not wanting to run. Last time I pulled it all out, my car idled terribly. This time it's similar, and my boost/vac gauge reads the full 30 InHg of vacuum. I know I capped off all the throttle body nipples, blocked the EGR port, capped the two solenoids behind the intake manifold (and left plugged in), and the charcoal canister and all connected vac lines are removed. I don't know why else it doesn't want to stay running.
I didn't do a full rebuild. Bought a complete 6 bolt long block, but using the short block with a 2g head. The head got cleaned and reassembled with the only new parts being the valve seals. I didn't pull any of the rotating assembly out, and it still has the balance shafts installed.
My only other thought, is that the CAS needs adjustment for timing, which in the 2nd video, I attempted, but it shut off before I could do anything.
In the 1st video, it finally starts at 28 seconds if you want to advance to that time.
[ame]http://www.youtube.com/watch?v=QnvuZMmKe9g&feature=player_detailpage[/ame]
[ame]http://www.youtube.com/watch?v=E_J1WPI965E&feature=player_detailpage[/ame]
