420A Car won't stay running
Copas97GS
Aug 9, 2023
Moberly, Missouri
The car was running, then the other day its started then died, I tried to start it again and rev it up to about 1000 rpm and it would run as long as i was keeping it at that rpm, there are DTC's for evap purge solenoid and Engine Coolant Temperature Sensor, could either/both of those keep it from running
Engine Coolant Temperature Sensor! It seems to be a common issue on the 420A.
The ECU is defaulting to a coolant temperature of 114F. This sensor controls a lot of things, including fuel injector duty cycle.
There is no listed “default” action for the emissions evap solenoid code other than the CEL.
I wonder if you kept it running at 1000RPM as you mentioned for a little while and let it heat up, if it would eventually run by itself after coolant temp actually got to 114F. :idontknow:
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
