Got a p0202 code and now p0201
Dsmj89
3,249
14
Nov 11, 2008
Miami, Florida
I'm at loss, yesterday i connected the obd2 scanner and i got a p0202 code, reconnected the obd2 scanner today and got a p0201, how the hell would all the sudden the injector 2 circuit would go from being faulty, to no more injector but now instead injector 1 ?
I'm going to turn on and off the car, and drive it around before reconnecting the scanner again.
Any ideas ?
i had something similar happen to me before on a different vehicle. it was a misfire on cylinder 4 then on 5. switch randomly. what it came down to was a cracked distributor cap. i know on the older dsm's that they dont have a distributor. just a coil pack. i would take it off and bring it to be tested. i dont know if you may have an issue with the computer either. but its just a thought to help you try and narrow results.
Thanks man. I tried a different ecu and nothing changed at the time either.
Same issue last year but I had faulty wire when my brother bought his eclipse so after some splicig and stuff shes fine. good luck figuring it out.
