GOT A NEW CLUTCH....Flywheel ?
jibberishballr
475
3
Aug 23, 2005
Chico, California
so i got a new spec stage 3 clutch kit....and it says i should resurface my flywheels since im not gettin a new one and its still the stock flywheel.....so i have a ?.........whats this "stepped" flywheel thing...(im new to drivetrain) and what would u do in my situation? if resurfacing is my only option then how much does that usually cost?
any help on any of those ?'s is appreciated
thanks!
Resurfacing the flywheel on a clutch install is critical to proper clutch operation. It is not expensive, but it should definitley be dont correctly. This link should be all you need. Right at the top under "Flywheel Step"
http://www.roadraceengineering.com/clutchandflywheeltech.htm
Oh, and settle down with the caps in your thread title. People will see your thread just fine. Also, use complete sentences whenever you are on here. Alot of people will pass up a thread if the person types in crazy fragments. Sometimes it is not clear what people are trying to say and it immediatley steers other members away from helping them. This will get you more help and respect from the entire community.
Hope I helped.
The step height refers to the distance between the clutch mounting surface and the friction surface on the flywheel. The Spec clutch you have recommends a .610" step height.
