Goofy question, whats the best Air/Fuel ratio?
definitiveno
1,237
8
Sep 8, 2004
Reno/Sacramento, California
This is not really a tuning problem I am trying to sort out or any thing just a question I have wondered about for a while. I read some where that 14.7:1 was stoichiometric, where all carbons would be consumed or some thing, and I also read that 11.5:1 produced the most cylinder pressure, it's ignition produced the most energy. Is there any truth in that? If not what Air/Fuel Ratio makes the most power, there has to be a scientific answer for this. It just seems that there would be a balance of air and fuel that would make the biggest pow. Any ideas? Any one?
That is an excellent link.
My personal experience on my 14b car and my friend's 16g car, all WOT stuff as I am only starting to understand how to tune light throttle stuff (more complicated than the WOT, IMO):
The cars generally seem happiest between 11:1 and 11.5:1 on pump 93, though I've never tried running leaner than 11.5:1. Everything I've read indicates that more power can be made with the richer mixtures so I haven't bothered. Around 10:1 and less, the cars have an obvious bog and will misfire out if you go much below 10:1. Going from low 10.x:1 to 11:1 is a very noticeable improvement in power and how smoothly the car runs. I wouldn't run lower than around 10.5:1 at the minimum. 11:1 seems to be a good happy medium setting that has allowed for decent power on my car and on my friend's car, so I usually just peg it there and go focus on getting boost to a reasonable range and then bumping timing. I'm currently running my car a bit leaner, 11.3:1 and I really don't notice much of a difference. In my experience 11:1 is a good WOT afr for pump gas with our cars and more can be had by cranking the boost and then seeing how far you can push the timing. Just a few degrees of timing advance can make a huge difference in power while a 10.8:1 to 11.5:1 isn't all that noticeable.
DSMs, and many factory-turbocharged cars, use fuel as a cooling medium as well as a source of power.
The "correct" ratio will dance all around. Then, there's the smog considerations, which don't seem to have a number stated for incinerated aluminum vapor.
