air fuel ratio
Err... none, and a lot? That's a really difficult question to answer, because it does not make much sense.
CFM is cubic feet per minute, which refers to how much air you are flowing. A/F ratio is the ratio between the amount of fuel and the amount of air entering your motor.
sorry about the wording
with a bigger turbo and the greater amount of cfm that is flowing will this affect the amount of fuel needed to be added to keep the correct air fuel ratio
If you mean "Will throwing a bigger turbo on make my A/F ratio change" then theoretically no. Any air being pulled through the MAS, no matter if a large amount or a little, will be compensated for and fuel will be added.
Now wether or now your stock fuel system will be able to add enough fuel for a large turbo is a hole different question.
Hope this helps
Right on. That's exactly correct.
The ECU knows you need more fuel and tries to compensate. However, in some cases (a lot, really) it doesn't have enough headroom to give you the fuel you need, because the injectors or fuel pump are to small.
thanks for the help
kpt4321 do you have any sites or threads on tuning info that i could read to help with my tuning
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
