ck1938
- 33
- 0
- Jul 26, 2005
Atlanta,
Georgia
My timing belt broke Thursday night, two days before I was going to have it replaced. It's a good reminder for the future, 60,000 miles and 64,000 miles aren't the same, get it replaced before 60,000, not after.
The good news is that I was going about 10mph and my foot was on the brake, not the gas, when it snapped. I took the covers off today and the belt didn't cause any damage that I could find. It was still in place around the sprocket, just slack. It looks like all I'll need to do now is put the new belt on. My repair guide has some diagrams for the 2.4 L engine but no pictures.
My first question is about something my manual says:
Before installing the timing belt, ensure that the left side (rear) silent shaft (oil pump sprocket) is in the correct position as follows:
1. Remove the plug from the rear side of the block and insert a tool with shaft diameter of 0.31 inches. (8mm) into the hole.
I was unable to locate any plug besides the oil pan one. Where is the plug located? And what block are they referring to?
My second question:
Does anyone have pictures of the 2.4 L timing belt as it should be. The tech article I found shows the 2.0 engine, which has more sprockets than my 2.4.
This is the 98 Spyder with a 2.4 liter engine and an automatic tranny. Thanks in advance for any help you can offer me.
My second question:
