LarryJoe
- 376
- 15
- Feb 10, 2012
Davisville,
West Virginia
So I just recently finished rebuilding both my bottom end and head. Everythings been running great except on the highway my temp gauge will start to raise, usually to 3/4 the way full. But as soon as I get off the highway it'll drop back down to normal and never gets hot while idling until today. I used a composite headgasket and ARP headstuds. I lubed all of them with the supplied lube, hand tightened the studs into the block, then torqued them in 3 steps. 45,60,95. I rechecked the studs today and all of them started moving at about 72ft/lbs so I retightened all back to 95. Would the fact that all of them were down about 23ft/lbs cause my warming up issue? And why did they lose so much torque?
