Gears Grinding
drc1
66
Jul 14, 2003
Tampa, Florida
When I was driving this morning I notcied that my car wasn't shifting as smoothly as it should. When I came to a complete stop and tried to put the car in first it would grind badly and not go... this is also true for reverse. Also second gear feels pretty rough. Could this be caused by low transaxle fluid? Or a MC/SC? Any help is greatly appreciated.
Thanks
Well, my axle bearing bracket broke a week ago and the axle was flopping around. It's fixed now, but the hard shifting just started last night. Would a bad MC or SC cause the problems that i'm having?
maybe your trannys gone... or close on its way.... you can check the fluid.... or just drain it and refil it.... but iam sure your tranny is gone.....
Nah it's def. not the tranny. It was the clutch adjustment rod, it was grabbing right off the floor. I adjusted it a bit and it feels a lot better now.
