Gauge problems!
but
190
Apr 7, 2009
Ridgecrest, California
I Just got my defi gauges in on friday BRAND NEW. I hooked everything up except the last gauge and everything works fine. When I added the last gauge in on the daisy chain,it freaks all the gauges out. I remove it and everything is fine again. I tried swapping gauges to see if one was faulty but same thing. Do you think I have a faulty control unit? I should be able to put 6 gauges in! The funny thing is it works If I have the lights on when I turn the key,but if I have the lights off and turn the ign on they freak out. With only the 3 gauges hooked up it doesnt matter it works lights on or off. Any help is great I can hardly find info on these.
what kind of gauge is the last one your trying to install, Or you just might have to run that gauge set up different. Sounds like your taping the power wires with a signal wire on that last gauge or something is touching
They are all the same. They should be easily daisy chained together.
